Combi Boiler recommendation rqd
24 Feb 2008
Leeds
Hi all, can someone recommend a Combi Boiler that has a plentiful HW flow at a decent temperature. I am looking to install a new central heating system and could do with some good feedback as to what Boiler to go for. Preferably one with a good track record as far as faults go and ease of servicing.
Thanks in anticipation.
what about a Viessmann Vitodens 333 if you have lots of room.
alternatively you have the usuall suspects as suggested Vaillant or
The CDi range from worcester bosch
Hi Guys,
Thanks for the prompt replies.
Essentially I'm looking for something so that the shower won't suddenly run cold if someone runs another hot tap in the house.
Reliability and ease of servicing are my next prime requirements, so advice from those who install and maintain them is greatfully received.
Peter
Ethos gives 22 litres/min. Alpha cd 50, ACV. All wall mounted. Less rates are W-b 40kW, Glow Worm 38 kW, Viallant 937. all wall mounted but he 937 is very big.
Floor mounted combis have very high flow rates. ACV HeatMaster, Gledhill Gulfstream, W-V HighFlow, Viessmann 333, etc, etc.
Alpha cd 50
Not that anybody needed another example of how you quote straight through your a***, but even you should be concerned that you've just recommended an appliance with unvented mains storage. You know, the ones that can cause more damage than a thermo-nuclear device.
Another explanation is that you don't know how the CD50 produces DHW and forgot to Google it.
Alpha cd 50
I know exactly about the CD 50. You have clearly lost as you are resorting to personal insults.
You've lost an argument with yourself by suggesting a product to the OP that you (not anyone else) consider inherently dangerous, you remember in your words 'not failsafe' etc... etc.... ad nauseum.
OP the CD50 is fine but if you check out Drivel's posts you'll find many inconsistencies.
