- Joined
- 9 Feb 2019
- Messages
- 4
- Reaction score
- 0
- Country
For a number of reasons our combi boiler needs replacing, so I'm looking for suitable replacements and would appreciate some input. It needs to meet the following spec;
I've been looking at;
Intergas, specifically HRE 36/30 and Eco RF 36 models which will meet the above and are under budget, although they need an external expansion vessel. 10 year warranty.
Worcester Greenstar 36CDi compact and 32CDi compact meet spec but are both more than budget. Five year warranty.
Baxi 636 which has a huge DHW flow rate of 15 l/m and a seven year warranty but I'm unsure about the brand/reliability.
Vaillant EcoFit pure 835 mets spec, is just over budget and 7 year warranty.
Any others I should be looking at or thoughts on the above? I'm erring towards the Intergas currently due to the warranty and seemingly sensible design - I have space for the external expansion vessel. The Baxi is tempting with the hot water performance, and stainless steel heat exchanger.
- Needs to be compact enough to fit in the existing space (under stairs outdoor cupboard) so similar to the existing 395x700x285 (WxHxD). There is around 120mm of clearance to one side for a slightly wider unit, but not much top & bottom due to sloping ceiling and existing pipes.
- Compatible with modulating demand, I have a Tado system which supports various protocols.
- DHW flow rate of 13l/m or better.
- Suitable heating capacity for seven radiators in a 1930's semi (for reference the current boiler is a 24kW and copes fine for heating).
- Budget around £1100.
