What's the 'best' temperature to set the temperature dials to, on the boiler itself?
British Gas say this:
If your boiler has two dials set the heating control at a high setting (80°C).
We had our boiler installed last year and one thing I found during the winter is that the room stat will bring it up to temp so the boiler will then shut off. 10 minutes later the temp will drop as boiler is off so it would fire up again.
Rinse and repeat. Can't be efficient to continuously fire on and off.
Ours does have separate dials for water and heating; the heating dial is currently set to about 45. We have TRVs on all rads.
