ok,,,,,,this is it....if the guage is running high on central heating and reads ok on hw only... also the prv- pressure relief valve might be open when pressure hi..>>.the filter strainer is blocked on return pipe to boiler..on mine the prv was dripping ..obviously blockage in system..when boiler cold the pressure will show low and u will be topping up..?
looks like large brass joint offset large nut...dont undo it......drain system..cen heating..then undo nut and u wiil find the filter..u can clean with toothbrush and a bit of brillo pad..when u can see through it side on its clean ..reinstall...use bit rtv on end cap joint...refill systemm,,,,,sorted..
refill boiler to approx 1 bar only..
obviously call plumber if u are not up to or unqualified.
u will need bleed rads after filling system..do this before switching boiler on
if boiler drops slight pressure-- bleed and fill system until 1 bar on guage.u may here a hissing noise..this is auto vent on boiler and will selfbleed boiler only....
hope it works for u..prob best replace prv at time of cleaning/replacing the strainer
if u are seeing hi pressure and the relief valve is not blowing off.usual copper pipe outside wall adjacent boiler (u will c steam!!)..turn off and call a plumber/heating eng...
