combi boiler will not fire up - it's freezin please help
5 Dec 2010
Somerset
I've have a worcester 28i junior that won't fire up in water or heating.
This seems to of happened since the water board changed the external stop cock. The pressure gauge is u/s and has been for a while but the heating/water was fine (i have orded anew one), I've bled the radiators and topped up the system to 1-1.5 bar.
You can see and hear the ignitor kick in but it won't fire up. Tried all the resets highlighted in the manual for water and heating to no avail.
The flume seems to be clear with no blockages and the pump doesn't feel hot. I've now bled and tested the pump which seems to be fine.
Pressure Vessel/Expansion Vessel seems fine 10psi when system hopefully at zero pressure (had to bleed radiators to a trickle...)
Can you help please?
