Hello
I recently moved to a new rented flat, with a combi boiler. So far we only used it for hot water and it has been working very well, strong hot shower pressure.
However it's been very cold the last few days so I decided to turn the central heating on. Pressure looks ok at 1 bar, no room thermostat only the temp control dial in the boiler. Initially the boiler refused to fire until I put the temperature control in the boiler to max.
Now the boiler fires for 30s, turns off for 30s, then fires again and so on. Water pump seems to be on all the time. Pressure gauge goes up to 1.5 bar.
The rads are warming up ok but very slowly, but do get hot to the touch.
Is that normal? Doesn't fell like the boiler should be going on and off so quickly. The boiler is also extremely loud when fired (not the water pump, which is constantly on, only when the flame is on).
Any ideas before I ask the landlord so send someone in or not to look at it?
