Combi Boiler
Oli
24 Aug 2004
If i get a thermostatic shower will I need a pump... and can a pump be fitted?
I have a combi boiler but the pressure is very low. When a tap is turned on elsewhere in the house pressure reduces alot. Will a thermostatic shower reduce or even stop this problem?
Thanks in advance
a thermostatic shower will not solve your problem
you cant pump the mains unless the flowrate is below a certain figure (chris r will no doubt post you the details i hope i cant remember) :D
Ok, so there is not much I can do to solve the problem presuming that the flowrate is above this figure.
Are there no other soloutions? Can nothing be done to the bolier to increase pressure?
is th pressure the problem or is it the flow rate where i am i get 3.5 bar of pressure running one tap run two it falls to .75 cos the main coming in is 1/2 in lead i still get the pressure not the flow if you follow my drift could be your problem :D
I see what you mean. If the water is not coming in fast enough to service the pressure demands then pressure will reduce. So increasing the flow rate internally could actually make little difference while using a combi.
From what you are saying whatever shower I get the situation will be the same. As long as the above it true?
A thermostatic shower would work at the same pressure as my current electric offering?
by jove i think youve got it
might be worth a call to your local water company if your pressure is low find out what the min should be :D
Thats great! Thanks for your help, I will get onto them tomorrow.
Thanks again!
