i need to replace my old boiler which is a standard gravity one with hot water cylinder, i am thinking of replacing it with a combi boiler, the one i am thinking of using is a baxi combi 105e ,anyone know if this is a good boiler or can you recomend one. cheers
valiants are my favourite at the moment......found baxi's a bit tempremental.The best thing is to pick a boiler suited to your needs then do a web search on it, boilers generally are made with a duff component if they are going to go wrong and tend to be good or bad by models rather than brands and when they make a duff model they get a good slagging off on the www!.
