combi boiler
28 Oct 2007
Buckinghamshire
Hi i have a problem with my wocester boiler,it keeps losing pressure 3 so called plumers and a few hundred pounds later still no joy. nobody can find any leaks. does anybody have any ideas they would be most welcome thank you.
Hi there, what model is it?
Is there any obvious signs of leaking at the radiator valves, tie some tissue around both of the valves on ewach radiator to start with.
If the tissue is dry after running the system for a while, the leak may be under the floor boards. (see below first though).
What pressure is the boiler before and after the boiler starts up?
