Hi all,
I've been looking around at combi boilers of late and have stumbked across something that i need answering.
for example a combi boiler on B&Q's web site states that it is 21KW. Now to me that seems quite high. I then thought that you would need to get power to this and that way could be by spuring off the ring main into a switched fused connection unit. That is when i frowned.
My calculations indicate you needing a high amp. it works at around 87.5 amps. Is this the correct way to do it as that seems rather high to me.
