combi boilers bahama whats the heating cycle?
28 Jan 2006
Staffordshire
hi
could somebody tell me if this is normal for a boiler
i have a baxi bahama combination boiler
is it right for the gas burners to be cutting in and out before it reaches set temperature
surely the burners should ignite and stay roaring away until it reaches set temp at controller (when hot water is calling the burners are on constantly as they should)
mine is calling for heat all the time but burners cut in and out (on for 10 mins off for two) but pump runs all the time irrespective of this .the only time when the pump switches off is when it reaches set temperature
is this correct ?????????????
could someone explain to me the correct heating cycle
thank you
