Hi All,
My water from my combi boiler all of a sudden has gone from kicking out hot water to luke warm.
I checked the bolier and saw that the settings were all at the same level as they had always been set to but the pressure was up from 2 to 3 (when not firing).
I turned the system off and bled some water out using the radiator value on one of the rads to get the pressure down but this did not fix either problem. The pressure went back up again the next day or so and the water is still not hot.
The filling loop is in the closed position.
The radiators get scolding hot still too (the 60 deg light is illuminated) but when a tap is turned on, the boiler seems to stop working and drop the temp down (the boiler lights go to 30 or 40 deg instantly).
Has anyone got any ideas or should I just get an engineer out asap.
Simon
Simon
