Our combi boiler is cutting out after the overheating light flashes.(obviously overheating)
If i turn down the comfort switch to below 4 the temperature light stays at 80 deg and the overheating light does not flash. Does the comfort switch adjust the flow of water or the amount of gas?
Could this be due to a slow pump and is there a way to check pump speed with a multi meter. If I unscrew the end cap on the head of the pump, water sprays continuously, is this normal? The heating side works fine.
The combi boiler is a Radiant Bruciatori RSF 20-24 pilot flame.
Thank you
Thank you
