Looking to take advantage of the scrappage scheme to replace current creaking boiler with a combi. Have a quote. Also got a question.
Combi is going in to bathroom airing cupboard where hot water tank currently is. There's a dedicated immersion heater circuit from the cu in twin core and earth (2.5mm2) that's been lying dormant for years- installer suggests using this supply for the combi.
Existing immersion heater circuit is from the non-RCD protected side of the CU and terminated in a FCU (but nothing connected to load and no fuse at the mo - supply is live) . There's space to move across the immersion heater MCB to the RCD protected side of the CU.
When the corgi (and apparently NIC/EIC registered) man comes to rip out the old tank and install the new combi, do I need to make sure he moves the MCB in the CU to the RCD protected side given that we're in a bathroom? Do I need to worry about anything else with this set up?
Is there an issue with location of the FCU in the cupboard given that door to airing cupboard not accessible from bath? Bath also has an electric shower on outside airing cupboard wall over bath so distance as crow flies (through walls) between shower and FCU short, but human arms unable to get anywhere near without punching thru marine ply.
I just want to make sure he does it properly, but I think building control will be involved anyway given mains pressure plumbing/gas installation, so presumably they will check?
Cheers for any advice as to what to look out for or ask.
Leighloz
Leighloz
