Hi, You all sound like you know what you are on about so...........
My valliant gas Combi boiler, was fine until last night when the heating stopped working, hot water is fine and the boiler does fire up when the timer/thermostat clicks on but no hot water in the radiators. I haven't heard any movement in them at all. Two weeks ago we put a nail through the hot water pipe that goes to the washing machine and had a plumber out to solder it - but we did switch off all the water then. Could we have an air lock somewhere? i was going to try and bleed the radiators tonight to see if that helped. I don't really want to do too much as i know nothing and am likely to cause more problems. What should i expect a plummer to charge me per hour labour? don't want to pay over the odds.
