- Joined
- 20 Apr 2014
- Messages
- 2,467
- Reaction score
- 0
- Country
I have a combi system,I have noticed that the
pressure drops to 0 when the system is switched off.When it is switched on the boiler is noisy and sounds like there is air
going through the boiler/pipes.Once the system is running the pressure returns to normal 2bar but then carries on climbing
until it is into the red on the gauge but then drops back to 2bar.When the system is
switched off it drops back to 0 within 15 min.I don't have any idea why this would do this,if there was a leak that drops the pressure to 0 how can it go back to normal and above without adding more water to get the pressure to normal.All the radiators heat up as normal and there are no cold spots,all
radiators are on the ground floor except one
in the loft conversion,the one in the loft runs off the standard system there are is no extra pump for the loft but this hgas been ok.We bought the house this way so any pointers or help would be much appreciated.
