- Joined
- 31 Dec 2003
- Messages
- 173
- Reaction score
- 1
- Country
This question is associated with my earlier one about a Grant Combi 90 that keeps losing pressure but I have posted it as a new subject as I hope it may provoke responses from others...
In an attempt to cure persistent loss of pressure in a Grant Combi 90 I replaced the pressure relief valve as it seemed there was a slight drip from the outlet. It seems that there is still a slight drip which I guess is an indication that the valve is opening. The boiler fires OK and the rads get hot and we get hot water, albeit at low pressure.
What could be causing the system to overpressurise so that the valve opens or leaks? If the heat exchanger was furred up could this cause a build up of pressure?
Hope I sound desparate 'cos I am!
Snowsride
Snowsride
