Combi problem. N o Hot water
5 Oct 2008
Nottingham
Hi, my combi isn't giving me hot water, it's running cold only. Any ideas what to check first or what it could be? It's a newish boiler, not ancient. Glow worm ultracom.
Heating works fine.
Thanks for your help
Any fault codes coming up on YOUR boiler ? press the plus and minus buttons under the rad symbol for the last ten faults.
Turn on the hot tap and press the minus button under the rad symbol for 3 seconds and post back what s code is showing.
just to let you know an engineer came around and said it was flow sensor that was faulty, and new one is ordered :) thanks for your help
