combi problem
20 Apr 2008
Gwent
I have ariston combi boiler hot water no problem when I turn on central heating boiler fires temperature is reached in seconds and cuts out no heat in any part of the system checked pump no problem completely drained and refilled system bled system no result any ideas welcome
If you told us which one of the 50 different Aristom models you have it would help!
In any case, there is clearly a very basic fault on your boiler and a restricted flow would be the first think tio check!
I am always supicious of those who say they have "checked" the pump. can you describe exactly what you have done to check it???
Tony
Thanks foryour reply exact model is aristonmicrogenus 11 checked pump by removing brass screw to check impeller is turning which it is. How would i check for restricted flow
youcantreallycheckapumplikethatwithoutexperienceoratachometermaybeitstimetocallsomeoneinitcouldbeotherthingstoo
Punctuation helps.
check u do not have a bypass valve fitted .it may have collapsed an allowing the flow through it
Have you made sure the auto air vent is open.Also it does seem a circulation proplem,you said you checked the pump,but because it's spinning doesnt mean it's doing it's job.How quick does it stay on and does the flow get red hot coming off the boiler,could be a blockage but unlikely,so see what the boiler temp gets to on the boiler,when it cuts off
How can i check if the pump is doing the job.
