I've got a problem with my Wickes halstead combi boiler. It was working fine yesterday. I'm in the process of doing my house up so am not staying there. I went back today and have had a new fuseboard installed for me.
I turned on the hotwater and the boiler started up, however the hot water didn't get hot. So I looked at the boiler saw that the burner hadn't come on and pushed the ignition lockout reset button. This got the burner to fire up, however after 10 seconds it cut off again. I pushed the reset button and had the same result. So i tried the heating, again the boiler started however the burner didn't come on again. So I pushed the reset button again and it did the same as before the burner came on for about 10 seconds and then just turned off again.
As I said it was working fine yesterday the only change is that i've had a new fuseboard installed, however as there is power to the boiler I can't see how this can have caused the problem (could be wrong though). The heating is full I checked the pressure and made sure there was no air in any of the rads. There is also gas to the boiler. So anyone got any ideas as to what is causing the problem? Typical always happens on a freezing night!
