Just recently my Combi has started mis-behaving. When I turn on the hot bath tap it starts filling fine then after a few minutes the flow drops to a trickle. If I turn off the tap, then on again the flow starts fine but then drops, there is also a hissing sound from the boiler.
I suspect a faulty diverter valve, but could this be caused by dirt in the Heating circuit or trapped air in the boiler ?
British Gas engineer suggested a trick with the mixer tap to clear it, something about turning hot and cold on together and putting your finger over the tap outlet .... what does this do ? (Apart from ensuring ALL of the kitchen gets a good soaking)
