Hello all,
Have just moved into a flat with a 1075 by 450 direct combination hot water cylinder. There is no shower since there'd be insufficient head from the tank outlet.
I was planning on fitting a small negative head pump (18 litres/min) to the hot water tank outlet. However, the cold water tank is only 20 litres so I was also planing on putting in a ball cock with as large an orifice as possible so that the water can be replenished quickly enough to provide a decent shower (or alternatively fit two independent ball cocks).
I've seen a similar setup with combination tank of the same size which worked but the pump "ran dry" occasionally when the hot water was allowed to run for too long. If this happens to my system, I was planning on putting an orifice up stream of the pump to restrict the flow and prevent this happening whilst still allowing the shower to function.
I've thought about going for an unvented system but am not keen on the expense and maintenance that this would entail so have decided against this....
Does anyone have any other ideas or comments?
