I'm looking to tidy up the point where aerial/satellite coax cables enter with one of the following outlet plates -
http://www.screwfix.com/p/labgear-screened-outlet-plate-quadruplex/91669
My 'problem' is that it requires a mounting box at least 35mm deep. The walls are solid brick, with a ~16mm plaster finish and I don't really want the hassle of chiselling a deeper hole from the brick. So a 35mm recessed box is out of the question, but a 35-40mm surface mounted box is going to look terrible. Is is possible to combine a 16mm recessed metal or plastic box with a shallow surface mounted box to create the required space without it projecting too far from the wall?
Alternatively, are there any other options I could/should consider?
