combis & showers
30 May 2007
Manchester
Hi , iv'e got a vaillant turbomax vuw 242/1e combi and the hot water presure has always been a little on the low side can this be increased and will it be ok to change from my electric shower to a thermostatic type and what type would work best :confused:
What is your hot flow rate from your boiler measure with a 1 litre container over I minute.
9 litres per min should give you a decent shower.
Pete
cheers for your reply i've measured it at about 7.5 ltrs per min can that be increased :)
Ensure your mains stop tap is fully open.
Use full bore service valves or gate valves.
Replace lead with mdpe (blue plastic) pipe with a larger bore.
Pete
Or even look under the boiler on the cold supply pipe to it there should be a little grey/white knob just as it goes into boiler make sure this is open fully
