Central Heating system problem....
I believe I have a combination cylinder (fitted in my basement of our 3 storey home) as it has a top section with a lid and a float/ball valve there when i take the lid off).
Bascically, water is seeping over from the top.
I have checked the ball valve & it looks fine. I have taken it apart, cleaned the washer and replaced (adding a slight bend in the arm) to lower the water level but this has had no effect.
I have temporarily removed the cold water connection to this ball valve in this top header tank BUT water still fills up there somehow & seep out.
I belive water is feeding up from the pipe from the bottom section of the cylinder tank.
The unit is about 6 years old.
There are no tanks in the loft at all, only a small potterton bolier on the 1st floor.
Any suggestions ? tri valve ? Pressure to high ?
