We're building a GF bedroom extension (single storey). We have created a warm deck roof with 120mm celotex and then GRP over the top of the structural deck.
As the room is for an elderly parent, I was thinking of adding further insulation (rockwool) in between the 400mm centre ceiling joists. I asked my building inspector if he would have any issues with this and he replied "Additional insulation (Rockwool or similar) can be installed between the joists but this should not leave a void between the two insulation layers. It would therefore be better to fully fill in between the joists and the firings without squashing the insulation too much. To do this you will need more than 100mm of insulation though. As the roof is a ‘warm’ roof, the top of the external walls should be built up or sealed with insulation to the underside of the warm deck roof to minimise any heat loss through the fascia."
Does he say this because of concern that there might be a temperature differential in the void between the top of the rockwool and first layer OSB3 which the 120mm celotex is sitting on? If so, surely the temperature differential wont be that much since the warmth inside will not really be hitting a cold ceiling?
Also, am I wasting money by adding further insulation between the ceiling joists as 120mm celotex on the roof is sufficient? The walls are insulated with 50mm celotex and the concrete floor will have 75-100mm celotex under the screed.
