We have been advised to replace two woefully inefficient older Ideal boilers (there are not linked and have a combined 60 kw max output if I remember correctly) with one small commercial boiler - a Worcester GB162 80kw boiler. We require around 72kw ish.
A bit of background- It is a large, older detached house ( long and narrow over 3 floors) which we have been doing up for over a decade. It will ultimately house 3 teenagers, 2 adults and reqular /extended visits from elderly parents. There is loft insulation and some cavity wall insulation. We are addressing where various extensions have been added without insulation. We use some rooms all the time, some like bedrooms at certain times of day and others only occaisionally.
We currently operate 4 zones on our existing system.
The heating being split into 3 zones the hot water a zone in its own right. The radiators have trvs but we do not have any room thermostats.
We want to try to maximise efficiency on a room level if possible. My questions are:
1. How do Worcester rank in terms of efficiency and longevity? Which other manufacturers should we be considering.
2. Is there any way/benefit of having room level heating control with out having a wall mounted room thermostat in each room.
3. Are weather compensators necessary/useful? Is there a difference between those that use the external temperature as opposed to internal only. (I read, somewhere on here, what I interpreted as someone only using the internal temperature).
4. Should we be going for a different type of system altogether?
5. Is there anything I haven't mentioned here that we should be considering /aware of.
Many thanks in advance.
StClaires
StClaires
