Commissioning link for Triton AS2000XT Poer Shower
2 Nov 2012
Clwyd
I have mislaid/lost the two pin commissioning link for my shower unit and have altered the plumbing so need to re-commission. It appears to me that the two pin link connects only to the switch therefore am I right in assuming that if I connect those two pins with my own connectors and loop that this will effectively switch on the water supply via the pump?
All that link does is allows the solenoid coil to open without the pump running to let water flow and bleed any air out of the system.
I useally just use an electrical screwdriver and touch the 2 terminals.
Be careful they are 230v.
Thanks SS for your quick reply. I thought as much but better safe than whoops!!
Cheers.
