Compact 28 hot water problem
23 Jan 2007
Hi
This Vokera boiler was installed 2 years ago and worked fine initially. I am now finding that the hot water is getting up to the required temperature set by the hot water dial but after a few seconds it goes cold and I mean cold to the cold water temperature. After a few seconds it get up to the hot temperature again then back to the cold. This began a few months ago and the ratio between the hot and cold was quite long. That is, it was hot for much longer than cold but now the ratio is about the same. 1:1 and therefore I cannot get enough hot for a bath. The central heating seems to be working fine. Any ideas. Thanks
This is most likely to be a blocked secondary heat exchanger.
Tony
Tony
there isnt one....its a twin pass heat exchanger.
there is very little in these boilers but i would suggest to prevent you spending more money than is necessary you get the boiler checked by engineer. could be a few things causing this fault.
