Guys, newbie calling--DIYer.
I'm intending to do a straightforward replacement of a 1200mm shower tray with a 1200mm x 700mm bath, because I dont want to make any structural alterations to the bathroom. Are there any particular issues to consider when fitting a compact bath? Any thoughts on whether it should be acrylic or steel? I already have an Aqualisa mains fed shower working from the plumbing which I intend to use for the bath feed--its in 15mm copper, so would it be OK to tag on 15mm feeds for the bath, given that when the shower is in use, the bath taps wont be so it wont affect the shower pressure? Water pressure is pretty good. Cheers.
