compatability of test leads
8 Dec 2005
Cornwall
hi i have megger test equipment and wondered if the leads will work with kewtech plug in testers i.e the r2?
Is it the wander lead, I believe they are 4mm standard.
Is there a reason for wanting kewtech rather than the megger ones, have found some cheap ones?
If your in doubt it is always worth while contacting the the manufacturers and hopefully you may get the answer.
senate only sell the kewtech R2 plug in tester and i only use senate for materials. not even sure if megger do one?
