I had a new composite door fitted in August last year and apart from a draught around the latch area (will get onto this shortly) the door opened and closed perfectly. However, around Jan time, when I closed the door (without lifting handle up), the latch engaged into the keep but I could still move the door forwards and backwards slightly. When I lifted the handle up the, the top and bottom latch engaged and the door closed firmly. This only happens when the sun (south facing) goes on it. Come the later afternoon, the door closes and latches in fine. If I adjust the keep, the door then closes fine but I can't doing this every day. I know it is probably to do with heat but I just can't understand what section is causing the door to not sit tight in the frame.
My second issue, is that there is a noticeable draught around the latch area. It does seem this section of the door doesn't sit as well to the trim compared to the top and bottom. I have put some thick (5mm) insulation tape on the actual door and that stops it but doesn't look great. It is not coming through the keyhole as I have tried this.
Any suggestions would be great. Thank you
