So we in process of refurnishing out 1960's bungalow.
It's MK2 Trust Steel Construction with London Brick outside and 50mm Straw Boards Panels fixed on the metal frame on inside.
So far i did one room and did remove 50mm starw boards on window side wall then i did :
build wooden frame out of tanalised wood
Apply roofing breathable membrane
100mm Cavity Insulation
18mm Plywood
15mm Blue Sound Proofing Plasterboards
75mm insulation in partition walls
Floor was also done similar way :
roof batten under floor joists
100mm insulation
DPM Membrane on top
18mm T&G Floorboards
All above made room lot warmer compering to rest of the house.
On top of that we going to fit new 3tri glazed windows in whole house.
We also will be adding Full MVHR system to eliminate any dampness issue in further.
Will be starting work on our main bedroom and been think to leave existing 50mm straw boards in place. This would save me lotz of time.
I had a look on R-Value and look like compress straw board are around 1.5 R-value so that means they have really good insulation prosperities.
Whole floor will be done same way as was done in smaller bedroom.
My plan for walls is to :
leave exiting straw boards in place ( as long there is no moisture damage)
fix 18mm plywood ( so we can fix something to walls if we want)
fix 25mm insulated plasterboards on 2 outside walls
rest to be done in 15mm plasterboards with 75mm insulation in stud walls,
Is this good way to do it or should i remove the straw boards and do same what i did in small bedroom.
Been trying to find more info online if anyone did similar thing but no look so far ???
Much appreciated for advice.
Luki
18mm Plywood
100mm insulation
DPM Membrane on top
Luki
