Compressing Rockwool
11 Sep 2011
Dorset
Hi All,
Was wondering if anyone knows what exactly happens if you compress standard mineral wool such as rockwool into a smaller cavity.
So if you have a 200mm thick roll and squeeze it into a 100mm cavity.
They say it reduces performance, but does anyone know to what extent? Are there any other problems associated with fitting it into a tighter space?
Thank you.[/b]
For heat insulation, compressing it will remove a lot of the trapped air, so the performance will be significantly reduced.
For sound insulation, compressing it increases the density, so performance will be improved.
I believe that if you compress 200 mm into 100 mm then you will have the thermal efficiency of 100 mm.
yep the same here the trapped air is 95% off the benefit 200 mm to 100 may give you 105mm worth call it half
That's really interesting - thank you everyone. Also that is exactly the figure I was after. Looks like I can't cheap out and use the mineral wool instead of Celotex in a 75mm cavity if I want it to stay warm!
