On polypropylene pipes why is there compression and push fit fittings. Apart from the slight difference in prices are compression fittings better than push fit for getting a secure tight fitting , would like some answers on this.
Also l'm putting a 32mm tee in my pipes under the sink so l would like to know what is the difference between 32mm 92.5 tee and a 90 degree 32mm tee. Will both work ok on draining waste water away from seperate waste runs.
