Can we use a compression joint below the floorboards on cold water pipes or should it be an end feed fitting soldered?
A compression joing is bound to leak at some point during it's life.
Only one inaccessible compression joint can be used and that is manipulative joints underground and that is for Table Y copper.
compression joints under floors will have forces acted on them more than above ground because of invariable foot traffic. This can cause the joint to fail.
for water, yes. for gas, no.
wait for the torrent of contradictions...
the efficacy of your remedial works would be questionable. surely 2 clips would be required.
disgruntled of t'north
