I put this in the DIY disasters forum, i appreciate that was probably not the best place to put it, but was hoping someone could help
Hi there,
Was undertaking some plumbing work over the weekend and have found that one of my compression fittings is leaky no matter how much i tighten it.
i have a flexi pipe coming from the original copper pipe connected to a smaller copper pipe which then fits to the tap connector. its those last two compression fittings that are leaking.
Is it possible to remove the middle shorter copper pipe and use something like this to connect the two flexi pipes together
http://www.diy.com/diy/jsp/bq/nav.j...ngs/specificationsSpecificProductType=sockets
also, this says its size is 19mm, does that mean the outer socket size is 19mm but would work well for the 15mm flexi male or is this for a 19mm pipe?
i'm its not ideal to have the two flexi hoses together but it was all i could and it was my first ever time pluming
T
Hi there,
T
