Some months ago I purchased an old Hercules bicycle that is fitted with Woods type tyre valves. Within a few weeks of getting the bike the tyres started getting soft but so far I've not been able to pump them to the correct pressure (65 psi) I've tried the normal bicycle pump and a car foot pump but only managed to get about 40 psi into them. I have a small 2.5 HP compressor and the sort of tyre pump gun they have in petrol stations. I went to a bike shop and bought an adapter which takes the valve thread to the larger diameter like a Schrader valve but this does not seem to work with the compressor gun. I think the problem is that there is nothing to press on the centre pin of the gun nozzle to let the air flow. On a car valve this pin engages with a similar pin in the valve and opens both simultaneously. Is there a different adapter available that presses on the pin in the nozzle?
