I think for soda blasting it's free air delivery is a little on the light side, but it should be ok for spraying with the appropriate filters and water separators etc.
I'd carefully check the requirements of any accessories you intend to use, and oversize the compressor somewhat.
John
I've got a similarly rated unit. (not the Clarke). I'd echo John's comment. Mine's OK for spraying, tyre inflation, blow gun etc. It struggles with any rotary tools though. Just about OK for occasional use with those.
