- Joined
- 21 Jan 2017
- Messages
- 112
- Reaction score
- 2
- Country
Hi Guys,
I am going to be installing a CCTV system on my property this week, though i have been skeptical on how to hide the wiring on the external brick wall. I do not want to recess the wires into to wall or through the cavity. I would just prefer to cable clip the wires on the brick wall and hope i could conceal the wires with some sort of external conceal trunking so it doesn't look like there are wires there? is this possible and if so what kind of trunking could i get which does make things look so obvious.
Ultimately, i just want the wires to be hidden concealed without having to drill cavities into the wall but in addition to not making the outside of my home look ugly.
Any ideas from you guys would be very much grateful.
The only time i will be drilling into the brick is when I collect all the external wires from the cameras together and drill a hole to put these through into the internal home and connect up to my cctv system inside. Followed by filling the hole and placing a burst plate on top.
There will only one cable coming from each camera because the cameras are POE (Power Over Ethernet) IP cameras, 8 cameras = 8 ethernet cables around the external of the home. How can i conceal this.
Thank you so much guys to all who answer in advance.
thank you.
thank you.
