CONCEALA WC CISTERN
14 Jan 2009
Surrey
Has anyone know where I can get a replacement 1/2" microvalve for a Conceala WC cistern? I've just taken the existing one apart and found a split in the rubber diaphragm - hence the constant overflowing!
Cistern is an Armitage Shanks Conceala - it's about two years old and came ready built-in to fitted bathroom furniture [now dis-continued].
One picture of inside of cistern and one of valve in the link below - address will need to cut and pasted -
//www.diynot.com/network/user_album_update.php?album_id=2008
There should also be some text showing against the picture of the inside of the cistern. If not the bottom feed is on the left with internal stop valve [white oval knob] and flexible connection to the bottom of the valve.
Problem solved - found small plumbers merchants who has sealing washers for just about every valve ever made!
