In the process of refurbishing the kitchen I discovered damp problems with the floor which was made out of old clay tiles resting on soil.
To fix a problem I got a builder to come in and lay a concrete slab.
He did that a couple of days ago and he is coming back to lay foam insulation and screed. I'm not sure whether the concrete is of the right depth and what it should be the depth of the insulation foam and the screed.
At the edge of the wall the concrete laid is 2 inches deep and the builder claims that in the middle of the room is deeper closer to 3 inches and that, that should be sufficient for what I'm trying to do.
He also plans to put 3 inches worth of insulation and another 3 inches screed. Does the dimensions and the combination of materials sound ok?
Also, once the screed is laid, I'm planning to put laminate floor, the builder tells me I only need to wait 2-3 days before I put the laminate down. Reading other postings on this forum I get the impression I should be waiting longer than that. Any suggestions here?
cheers
cheers
