I have moved into a house with a large conservatory at back with a concrete floor - not very smooth but seems sound and dry. I dont have enough clearance with doors to build a joist structure so I intend screwing down 1cm thick plyboard and then putting lino over this.... is 1cm thick enough? should I lay down some hardboard sheets first to improve surface before plyboard? is there any risk of cold concrete rotting the hardboard/plyboard? do I need to lay membrane or foam sheet first or even some carpet underlay? [I cant get involved in pouring cement or screed because my wife is very allergic to certain chemical and also we dont have the time/space]
thank you for any advice
