Concrete block shed base
13 Oct 2008
Warwickshire
Hi, I am getting a new 10x8 shed delivered in about three weeks, and I still need to sort out a base.
I am thinking about getting some dense 7N concrete blocks, and laying 8ft wooden fence posts on these. eg something like this (not my photo)
Can I just lay the concrete blocks in a hole in the soil so that about half of the block is buried? I think I will need to put some sub base material into the hole first and compact it down, or could I use some large gravel which I already have? Should the concrete blocks be mortared into the hole?
This is my plan:
Will this work?
PC
Overdoing the footings will be a blessing in the future as the ground gets soggy, and allows the blocks to drop a tad lower. Saves you jacking up the frame I the future to add an additional block.
See if you can 'sister' the lengths, and protect the ends of the wood with something to stop them rotting?
Hi, when you say overdoing the footings, what do you suggest? Perhaps fixing the concrete blocks with some post mix?
And what do you mean by sister the lengths? Double up?
Cheers.
Overdoing as in increasing the coverage of the footing? Elephant foot compared to a gazelles foot so to speak?
Yes, doubling up. Less gluing them, more nuts and bolts?
Did you just put the blocks on the sub base/hardcore/ or did you use any kind of sharp sand/cement dry mixes well on top of that.
Putting mine just on the mot hardcore at the moment and was wondering if I should bed onto sharp sand as well?
Doing the same at the moment so any advice would be great?
Will a dry mixed sand/cement be prone to moving over time, so just using the hardcore would be better?
Forget hardcore and forget or mortar. Hammer the blocks firmly into 4" of stiff concrete. Lean mix is fine, like 1 : 3: 6 cement, sand, stone
