It'll be fine.
How are you planning on cutting them?
The only sensible way I can see is with a grinder. But a 115/125mm grinder won't achieve a 55/60mm deep cut, more like a 40-45mm cut, due to the configuration of the machine, but that should be sufficient to achieve a relative clean cut, with a light tap.
A 230mm grinder would be better.
You'll need the correct disc.
It'll be very dusty.
