I have a concrete porch canopy that I presume is origanal fit to what is a 40's ex council house. All most all the houses have then in various states of repair but given the cracks and the amount of rebar hanging out the side something is going to need to be done sooner rather than later even though at present im not worried about it fell on it own accord.
Looks a bit like this, only unfinished concrete a million times less twee and new looking.
Clearly built into the wall and the only 'lintel' as such over the door, none of the windows have lintels in the outer skin.
I cant be the only one in the same situation and trying to bodging them up a bit, so whats the chance of fixing it up with some epoxy or similar before painting it with something weatherproof for another 5 years?
Failing that I guess its a case of cutting it off as close as you can get with a stihl saw and fixing a simple wooden replacement in its place hung off the wall above on a pair of steel ties?
Daniel
Daniel
