Concrete fence post fixing
14 May 2007
Kent
Hi
Can anyone advise me how to attach a concrete fence post (slotted for a panel) to a brick wall. Alternatively, can you purchase a concrete fence post with pre-drilled holes at right angles to the fence slots?
Regards Malcolm
why do you want to attach a concrete post to a brick wall?
If the answer is "to put a fence panel in" then fix a wooden post to the wall, and use galvanised panel clips. Raise the bottom of the post off the ground to prevent rot.
Hi
Regards Malcolm
If you really want to attach it to the wall then just drill holes in it! Make sure you put a few washers between post and wall though.
I'd go with JohnD's suggestion though but make sure you space it from the wall.
I have fixed these posts (not the H type but the end type) to brick walls a few times using Raw bolts. You drill a 10mm hole in the post and a 8mm hole in the brick wall and the bolt makes its own thread in the 8mm hole as you twist it in with a socket wrench or spanner. most builders yards supply these type bolts.
