I am going to dig and fill a trench for a new porch. following this i need to fill with concrete.
After this i will let the bricky do his thing.
I have access to a cement mixer should i need.
The footing will be 1 meter deep(as advised by architect) and 600mm wide.
Now how much concrete should i put in. I know it has to be minimun 200mmish. Should i just fill it quite high up? around 90cm?
should i fill it a bit less and have 1 course of engineering block?
should i just fill it about 300 and thats it?
what are your thoughtss
In addition per m3 cube how much jumbo bags of balast(850kg) and normal size bags of cement should i use?
Cost is a important factor here for me.
