Hi Guys,
I am starting to cost up how much I need to get rid of my old sheds and get a nice new Log Cabin in my garden. When we bought the house a couple of years ago, we knew we would need something bigger as we did not have a garage, so this has always been the master plan. I am looking at a 5mx5m log cabin by Tuin, which seems to fit the build and budget, so that it pretty much sorted. Now to what I consider the hard part. The base. As we are going to be using it as a workshop / storage / tabletennis room, I was thinking of keeping the floor in the cabin concrete. This should save a few hundred pounds on extra wood and have a really solid flooring. My garden is almost 7 meters wide, so the should be plenty of room at the sides for painting and maintenance. At the moment I have a raised concrete base that one of my sheds is already on (approx 3m x 2.5m). I would like to use this as part of my new base. Is this usually a good idea? Also I would like the finish on the concrete floor to be pretty smooth, like you get in garages. Do you do this finish when you make the base, or screed it after once the cabin is in? Also would just a layer of DPM be enough to stop moisture, or would I need to seal the flooring?
Also my house has side access, which is a godsend. The base is probably 100 feet to the roadside. Would it be possible to get a concrete truck and pump the concrete directly to the base at that distance? Also is this size base doable in 1 go?
If I was also to pay someone to do this, what would I be looking at, cost wise...
Thanks in advance...
Nick
Nick
