Hi
Planning to build a double garage with internal dimensions 7.1m x 7.1m.
Plan to install 125mm of readymix concrete with A193 7mm reinforced mesh fitted 50mm up from the base of the concrete ?
I take it that this will more than support the weight of 2 cars ?
I plan to install 20mm expanded polystyrene around the perimeter of the concrete slab to act as an expansion joint.
Would this work or should I plan for a true expansion joint in the middle of the floor ?
Cheers
Cheers
